[Qgis-user] Circle around each point each with different radius
Joris Hintjens jorishin at gmail.com
Sun Mar 27 10:28:03 PDT 2016
HI,
Go to properties>style>Size. klick on the formula icon and define the fiels where the parameter is defined. Take care that in the CSV, that field is defined as Integer, and not as “String”.
should work.
Joris
> Op 25 mrt. 2016, om 19:54 heeft Nicolas Cadieux <nicolas.cadieux at archeotec.ca> het volgende geschreven:
> Hi,
> If disolve is the problem, try the grass disolve tool in the processing toolbox.
> Nicolas
> Le 2016-03-25 14:28, azf100 [via OSGeo.org] a écrit :
>> Hi,
>> I have a .csv with lat, long, radius. I want to create a circle around each point based on the input radius. I imported the .csv and tried using the geoprocessing buffer tool but when I select dissolve, nothing happens.
>> Any thoughts?
>> If you reply to this email, your message will be added to the discussion below:
>> http://osgeo-org.1560.x6.nabble.com/Circle-around-each-point-each-with-different-radius-tp5258378.html <http://osgeo-org.1560.x6.nabble.com/Circle-around-each-point-each-with-different-radius-tp5258378.html>
>> To start a new topic under Quantum GIS - User, email [hidden email] <x-msg://11/user/SendEmail.jtp?type=node&node=5258382&i=0>
>> To unsubscribe from Quantum GIS - User, click here <applewebdata://48623F53-C122-4437-95BA-A3C87DCB6AC2>.
>> NAML <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Circle around each point each with different radius <http://osgeo-org.1560.x6.nabble.com/Circle-around-each-point-each-with-different-radius-tp5258378p5258382.html>
> Sent from the Quantum GIS - User mailing list archive <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160327/423b4897/attachment.html>
