[Qgis-user] creating a python plugin to autopopulate some of the Georeferencer properties
Eric Goddard egoddard1010 at gmail.com
Mon Mar 28 10:36:42 PDT 2016
Thanks Nathan, looking forward to 2.16 :)
In the meantime I'm working on a plugin similar to the ArkPlan
georeferencer (using the GeorefGraphicsView from ArkPlan) , but I'm
going to temporarily use the hacky solution until I can get that
finished, which brings me to my next question:
If I I iterate over iface.rasterMenu().actions() and print each item's
objectName, the only ones that show up are
mActionShowRasterCalculator, mActionShowAlignRasterTool, and settings;
the rest are empty strings. If I print each item's text, I get the
menu text for each submenu on the rasterMenu, so the Georeferencer
shows up as "&Georeferencer". How do I access the actions on the
submenus within the rasterMenu()?
Just out of curiosity I did the same iteration over
iface.rasterMenu().children(), which lists only one QMenu object
(Terrain Analysis).
Thanks for all of the feedback!
Eric
On Sat, Mar 26, 2016 at 8:50 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Don't stress. I'm going to move it to core in 2.16. Will let you know once
> it's done.
> - Nathan
> On Sat, 26 Mar 2016 11:21 pm John Layt <jlayt at kde.org> wrote:
>> On 26 March 2016 at 00:03, Eric Goddard <egoddard1010 at gmail.com> wrote:
>> > Awesome, thanks John. We have about the same number of images to georef
>> > so
>> > that will be a big help. I looked at the georeferencer code which is how
>> > I
>> > discovered that some of the properties were stored in QSettings. I'm not
>> > too
>> > familiar with c++ though, but since the qgis api can be used to do
>> > custom
>> > applications I was hoping for a constructor for the georeferencer that I
>> > could use.
>> I did look at forking the C++ georeferencer and adapting it, or
>> perhaps creating my own python bindings using SIP, but the thought of
>> having to maintain and install compiled versions for all three
>> platforms just seemed more hassle, even though I am a C++ developer.
>> Trying to think of hacky ways to do this you could trigger the
>> mActionRunGeoref QAction via QgisInterface.rasterMenu().actions(), but
>> that would only open the georeferencer, it wouldn't get you having the
>> right file preselected, there simply isn't an api or setting to do
>> that. I guess it would allow you to have a plugin that when clicked on
>> presets the settings you need (including directory) before launching
>> the georeferencer.
>> The ideal would be to move a lot of the code into the public api with
>> python bindings and have a processing plugin so it can be python
>> scriptable, but I just don't have the time to do that. One day the
>> poor usability will get too much though and I will fix it...
>> John.
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
