[Qgis-user] qgis essen + postgis / long project init times
Jürgen E. Fischer jef at norbit.de
Wed Mar 30 00:16:30 PDT 2016
Hi Flo,
On Tue, 29. Mar 2016 at 23:34:52 +0200, Florian Lohoff wrote:
> The geometry column way is defined like this:
> 	way                | geometry(Geometry,4326) |
The missing constraint on the geometry type causes this.  Not sure if also
asking for srid and dimensions adds much.
You could start off with using the "use estimated metadata" option in
the connection - which is generally a good idea for large layers.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160330/cf477308/attachment.sig>
