[Qgis-user] Selecting records
Pierre-Marie Le Dantec pierremarie.ledantec at gmail.com
Wed Mar 30 13:17:14 PDT 2016
Do tou have an error or result is not as expected ?
If qgis complains about sql query or invalid layer, it can be because i
forgot fields calculated through a function need to be explicitly named:
SELECT stationid, MAX(obs_date) AS max_date FROM your_layer GROUP BY
stationid
This should works on any valid layer. Tested successfully with a GeoJSON
layer.
Pierma
Le 30 mars 2016 21:19, "Phil (The Geek) Wyatt" <phil at wyatt-family.com> a
écrit :
> Alas, this doesn't seem to work on the GEOJSON linked layer
> *From:* Pierre-Marie Le Dantec [mailto:pierremarie.ledantec at gmail.com]
> *Sent:* Wednesday, 30 March 2016 3:59 PM
> *To:* Phil (The Geek) Wyatt
> *Cc:* Qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Selecting records
> Hi Phil,
> For manipulating dates throught SQL you should use ISO format
> ("YYYY-MM-DD").
> Then, you can use a virtual layer with :
> SELECT stationid, MAX(obs_date) FROM your_layer GROUP BY stationid
> Cheers,
> Pierma
> 2016-03-30 13:09 GMT+11:00 Phil (The Geek) Wyatt <phil at wyatt-family.com>:
> I must be thick, but I can't get my head around this in QGIS
> Data
> stationid_
> obs_date
> BK21
> 28/03/2016
> BK21
> 29/03/2016
> BK21
> 30/03/2016
> BL22
> 28/03/2016
> BL22
> 29/03/2016
> BL22
> 30/03/2016
> BL22
> 31/03/2016
> How do I select the Maximum date for each station ID?
> The data will be coming from a GEOJSON feed but I can also pull it as a
> shape file if needs be
> Cheers - Phil
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> 73.64.34
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160331/3d59ba87/attachment.html>
