[Qgis-user] How to create valid new shapefiles with qgis and a buffer around?
Marcel Krautkrämer marcelkrautkraemer at mail.de
Sun May 1 09:26:12 PDT 2016
I created new shapefile layers (point, line and polygon) with qgis and tried
to create buffers around, but it does not work properly -> the buffer is
much to large, I want to create a buffer with e.g. 40 m and then the buffer
is much bigger.
Since buffering works fine with other shapefiles (that are not created by
me with qgis), my created shapefiles must have mistakes.
Can anyone help?
My example files:
https://www.dropbox.com/sh/9nl6b1vkghfxzl3/AABprQ-5ck4je8-sTqWafZx_a?dl=0
Thanks in advance and
best regards
Marcel
OpenSuse 13.1
QGIS-Version
2.8.8-Wien
QGIS-Codeversion
exported
Kompiliert gegen Qt
4.8.5
Laufendes Qt
4.8.5
Kompiliert mit GDAL/OGR
2.0.2
Läuft mit GDAL/OGR
2.0.2
Kompiliert mit GEOS
3.5.0-CAPI-1.9.0
Läuft mit GEOS
3.5.0-CAPI-1.9.0 r4084
PostgreSQL-Client-Version
9.2.14
SpatiaLite-Version
4.3.0a
QWT-Version
5.2.3
PROJ.4-Version
492
QScintilla2-Version
2.7.2
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160501/23821e16/attachment.html>
Type: application/x-dbf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160501/23821e16/attachment.bin>
GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160501/23821e16/attachment-0001.bin>
Type: application/x-esri-shape-index
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160501/23821e16/attachment-0002.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160501/23821e16/attachment-0003.bin>
