[Qgis-user] Plugin Building
Tudorache, Marian Marian.Tudorache at navcanada.ca
Mon May 2 11:53:40 PDT 2016
Hi Tyler,
Yes I did but I need the whole error stack message.
Can you paste in your email the whole error stack?
In that message it is the answer.
Marian
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Tyler Veinot
Sent: April-22-16 3:00 PM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Plugin Building
Hello All;
I am using QGIS 2.14.1 and am trying to build a python plugin using the plugin builder using this tutorial;
https://anitagraser.com/2014/04/26/getting-started-writing-qgis-2-x-plugins/
and the information here;
http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/plugins.html#init-py
But when I complete the first few steps and get to installing the plugin to see a blank interface I get error when calling it's classfactory method in the utils.py and __init__.py and I am not sure what is causing this error. I think I must be missing some required modules or something. These scripts are generated by the plugin builder and are suppose to call up the basic qgis and qt functions to my understanding.
Has anyone ran into this before?
Thanks
Tyler
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160502/b8c11fce/attachment.html>
