[Qgis-user] How to set python search path for standalone script?
David Shi davidgshi at yahoo.co.uk
Wed May 4 05:34:29 PDT 2016
Hello, Jurgen,
In Windows QGIS.bat, it has also got the same content.
@echo offcall "%~dp0\o4w_env.bat"@echo offpath %OSGEO4W_ROOT%\apps\qgis\bin;%PATH%set QGIS_PREFIX_PATH=%OSGEO4W_ROOT:\=/%/apps/qgisset GDAL_FILENAME_IS_UTF8=YESrem Set VSI cache to be used as buffer, see #6448set VSI_CACHE=TRUEset VSI_CACHE_SIZE=1000000set QT_PLUGIN_PATH=%OSGEO4W_ROOT%\apps\qgis\qtplugins;%OSGEO4W_ROOT%\apps\qt4\pluginsstart "QGIS" /B "%OSGEO4W_ROOT%"\bin\qgis-bin.exe %*
But, I do not know how to use this information in Python, to set runtime path.
Regards.
David
    On Wednesday, 4 May 2016, 12:50, Jürgen E. Fischer <jef at norbit.de> wrote:
 Hi David,
> I am writing a standalone script, but it can not import qgis.core and other processing.   modules.
In OSGeo4W there is a batch file python-qgis.bat you can pass your script to:
@echo off
@echo off
set VSI_CACHE=TRUE
set PYTHONPATH=%OSGEO4W_ROOT%\apps\qgis\python;%PYTHONPATH%
"%OSGEO4W_ROOT%"\bin\python.exe %*
PYTHONPATH and QGIS_PREFIX_PATH are most important.
Jürgen
Jürgen E. Fischer          norBIT GmbH            Tel. +49-4931-918175-31
Dipl.-Inf. (FH)            Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer          D-26506 Norden            http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160504/b927057e/attachment.html>
