[Qgis-user] Printed map scale question
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri May 6 12:30:10 PDT 2016
I have never used it but there is an Atlas creation tool in Qgis.
Nicolas
On May 6, 2016 7:35 AM, "Sarah Gregg [via OSGeo.org]" <ml-node+s1560n5264906h47 at n6.nabble.com> wrote:
Here I am back again with what may well be a very simple question (though perhaps with a negative answer). I have digitalised a zoning map on a 1:25,000 base (for Italian readers, IGM 1:25,000). So far so good. Now I have to render the results in a clearly legible high resolution image for printing. To display the full map on the screen, I have to set the scale at 1:185.000 and obviously if I create an image file at this scale using the Composer, even if I set the resolution high, the base map is scarsely legible. Is there any way I can get an image of the whole map at, say, 1:75000... apart from creating a whole series of image files and then joining them together using image processing software? Many thanks for your advice, Sarah.
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Printed-map-scale-question-tp5264906.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Printed-map-scale-question-tp5264906p5265030.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160506/ec5f8db0/attachment.html>
