[Qgis-user] (no subject)
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed May 11 05:13:26 PDT 2016
I remember reading an article by Anita Graser explaining that the modeler did not yet have conditional modeling.... I may be wrong as Qgis changes rapidly.
https://anitagraser.com
On May 11, 2016 01:28, "Sebastian Teßmer [via OSGeo.org] " <ml-node+s1560n5265686h27 at n6.nabble.com> wrote: Hello everybody,
there is in the graphical modeling in QGIS the possibility
install error routines, or when an error occurs in the execution
skip to the causative fault? and at the next Process to continue?
For example:
-> I use the process "extract After attribute value"
-> Now there is this value not -> entire routine is aborted
-> But instead QGIS should perform another routine
Unfortunately, I have found nothing in the documentation.
Many thanks and greetings,
Sebastian
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/no-subject-tp5265686.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/no-subject-tp5265686p5265776.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160511/eab51737/attachment.html>
