[Qgis-user] Attribute table error in QGIS 2.15.0-Master
Neumann, Andreas
a.neumann at carto.net
Wed May 11 05:56:43 PDT 2016
Hi Gustavo,
It is a known issue and already fixed in master. So either compile
master yourself or wait for a new nightly.
Greetings,
Andreas
On 2016-05-11 14:48, Gustavo Martínez Puljak wrote:
> Hi,
> I am using QGIS 2.15.0-Master in a 64bit Linux system. When I open the
> atribute table for a layer (postgis or shape) all the columns repeat the
> data of the first column (including the name of the column). The number
> of columns is correct. The data is correctly shown in form view, but not
> in the tabular view.
> Thanks in advance.
> Gustavo
> Gustavo Martínez
> Skype: gmpuljak
> Linkedin: http://ar.linkedin.com/in/gustavomartínezpuljak
> "Que la tierra se vaya haciendo camino ante tus pasos,
> que el viento sople siempre a tus espaldas,
> que el sol brille cálido sobre tu cara,
> que la lluvia caiga suavemente sobre tus campos y,
> hasta tanto volvamos a encontrarnos,
> que Dios te lleve en la palma de su mano."
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160511/e123e529/attachment.html>
