[Qgis-user] Export plugins list
Raymond Nijssen
r.nijssen at terglobo.nl
Thu May 12 06:56:28 PDT 2016
Never tried, but i expect that you can just copy the contents of your
old "plugins" directory to your new. In my case this is:
~/.qgis2/python/plugins/
Raymond
On 14-04-16 11:21, Joris Hintjens wrote:
> No answer anyone?
> I had the same issue some months ago. Did it manually. (print screen of plugin list to transmit the info)
> greets
> joris
>> Op 11 apr. 2016, om 10:33 heeft ah franz <ahfranz73 at gmail.com> het volgende geschreven:
>> it's possible make a command to export the list (xml) of installed plugins ?i.e. for transfer in other pc .
>> Thank's Franz
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
