[Qgis-user] Changing the language in QGIS
Tudorache, Marian Marian.Tudorache at navcanada.ca
Fri May 13 11:12:26 PDT 2016
Hi again,
I have found it. It is QGIS2.conf file .
Marian
Sent: May-13-16 2:05 PM
To: qgis-user at lists.osgeo.org
Subject: Changing the language in QGIS
Hi everyone,
I switch my QGIS to use French by Overriding system locale.
Can somebody tell me in which file is store the chosen language?
Thanks,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160513/fe0fb345/attachment.html>
