[Qgis-user] problem with QGIS installation
Filipe Dias
filipesdias at gmail.com
Fri May 13 15:21:32 PDT 2016
It seems that was the case. I cleaned the repositories list and now it
seems to be installing.
Thanks a lot.
Cheers
F.
On Fri, May 13, 2016 at 11:17 PM, Randal Hale <
rjhale at northrivergeographic.com> wrote:
> Did you disable the old repo and remove the old install? It looks like you
> have a mixed install of Ubuntu Gis and the QGIS install
> On 05/13/2016 06:03 PM, Filipe Dias wrote:
> Thanks Randal. Unfortunately now I have a different problem...Any ideas?
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
> python-qgis : Depends: python-qgis-common (= 1:2.14.2+20trusty) but it is
> not going to be installed
> Depends: python-qscintilla2 but it is not installable
> Depends: python-pyspatialite but it is not installable
> Depends: libqgispython2.14.2 but it is not going to be
> installed
> Depends: libqgis-analysis2.14.2 but it is not going to be
> installed
> Depends: libqgis-core2.14.2 but it is not going to be
> installed
> Depends: libqgis-gui2.14.2 but it is not going to be
> installed
> Depends: libqgis-networkanalysis2.14.2 but it is not going
> to be installed
> Depends: libqgis-server2.14.2 but it is not going to be
> installed
> Recommends: liblwgeom-dev but it is not installable
> qgis : Depends: libgdal1h (>= 1.8.0) but it is not installable
> Depends: libgeos-c1 (>= 3.4.2) but it is not installable
> Depends: libqgis-analysis2.14.2 but it is not going to be installed
> Depends: libqgis-app2.14.2 but it is not going to be installed
> Depends: libqgis-core2.14.2 but it is not going to be installed
> Depends: libqgis-gui2.14.2 but it is not going to be installed
> Depends: libqgis-networkanalysis2.14.2 but it is not going to be
> installed
> Depends: qgis-providers (= 1:2.14.2+20trusty) but it is not going
> to be installed
> Depends: qgis-common (= 1:2.14.2+20trusty) but it is not going to
> be installed
> Recommends: qgis-plugin-grass but it is not going to be installed
> Recommends: qgis-provider-grass but it is not going to be installed
> Recommends: qgis-plugin-globe but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> On Fri, May 13, 2016 at 9:16 PM, Randal Hale <
>> UbuntuGIS is in the middle of being revived. For right now I'd go with
>> this:
>> deb http://qgis.org/debian trusty main
>> deb-src http://qgis.org/debian trusty main
>> Remove your current installation/repos and install it from the above.
>> You will most likely need to do the following also:
>> wget -O - http://qgis.org/downloads/qgis-2015.gpg.key | gpg --import
>> gpg --fingerprint 3FF5FFCAD71472C4
>> Join the UbuntuGIS Email list it should be updated shortly.
>> http://lists.osgeo.org/mailman/listinfo/ubuntu
>> Randy
>> On 05/13/2016 03:52 PM, Filipe Dias wrote:
>> Hi
>> I'm installing QGIS on a clean Ubuntu 14.04 installation but I'm getting
>> this error. I have these two repositories installed. Any idea about what's
>> happening?
>> Thanks
>> Cheers
>> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu trusty
>> main
>> deb http://qgis.org/ubuntugis trusty main
>> fd at fd-Lenovo:~$ sudo apt-get install qgis python-qgis
>> libcogl15 : Depends: libegl1-mesa-drivers
>> E: Error, pkgProblemResolver::Resolve generated breaks, this may be
>> caused by held packages.
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Randal Hale
>> North River Geographic Systems, Inchttp://www.northrivergeographic.com423.653.3611 rjhale at northrivergeographic.com
>> twitter:rjhale http://about.me/rjhalehttp://www.northrivergeographic.com/introduction-to-quantum-gishttps://www.facebook.com/NRGSInc
> Randal Hale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160513/a35cab40/attachment.html>
