[Qgis-user] crayfish 2.2. plugin qgis 2.14 on Debian 8.4 bit 64
Su Hartono
gsuhartono at gmail.com
Mon May 16 00:29:07 PDT 2016
I get problem crayfish 2.2. plugin qgis 2.14 on Debian 8.4 bit 64 not
working very well.
This is the message.
Couldn't load plugin crayfish due to an error when calling its initGui()
method
OSError: libhdf5.so.7: cannot open shared object file: No such file or
directory
File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 315, in
startPlugin
plugins[packageName].initGui()
File "/home/tono64/.qgis2/python/plugins/crayfish/plugin.py", line 73, in
initGui
if not ensure_library_installed():
File "/home/tono64/.qgis2/python/plugins/crayfish/gui/install_helper.py",
line 133, in ensure_library_installed
load_library()
File "/home/tono64/.qgis2/python/plugins/crayfish/core.py", line 85, in
load_library
lib = ctypes.cdll.LoadLibrary(libpath)
File "/usr/lib/python2.7/ctypes/__init__.py", line 443, in LoadLibrary
return self._dlltype(name)
File "/usr/lib/python2.7/ctypes/__init__.py", line 365, in __init__
self._handle = _dlopen(self._name, mode)
directory
Python version: 2.7.9 (default, Mar 1 2015, 13:01:26) [GCC 4.9.2]
QGIS version: 2.14.2-Essen Essen, exported
Python Path:
/usr/share/qgis/python
/usr/share/qgis/python/plugins
/usr/lib/python2.7
/usr/lib/python2.7/plat-x86_64-linux-gnu
/usr/lib/python2.7/lib-tk
/usr/lib/python2.7/lib-old
/usr/lib/python2.7/lib-dynload
/usr/local/lib/python2.7/dist-packages
/usr/lib/python2.7/dist-packages/PILcompat
/usr/lib/python2.7/dist-packages/gtk-2.0
/usr/lib/pymodules/python2.7
/home/tono64/.qgis2//python
-- Thank you for your help --
Suhartono
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160516/efa75326/attachment.html>
