[Qgis-user] Use all cores for geoprocessing?
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon May 16 06:21:17 PDT 2016
Some GDAL raster processing modules use multiprocessing.  If you click on the help button in the GDAL Windows (that opens when you click on a GDAL function), you will see more info on the application.  Some like gdal_grid have a switch like -all_CPU (or something like that).  If you add that to the script (yellow pencil) that will activate the function.
Nicolas
On May 16, 2016 6:18 AM, "ginetto [via OSGeo.org]" <ml-node+s1560n5266615h26 at n6.nabble.com> wrote:
	I should rectify... in this moment processing MT support is
experimental and available only in the branch of the GSOC project.
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli * GitHub: https://github.com/luipir * Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis **************************************************************************************************
On 16 May 2016 at 11:58, Luigi Pirelli < [hidden email] > wrote:
> MultiThreading was introduced for rendering of different layer... in
> layer rendering is on single core.
> A GSOC project ( https://qgisgsoc2015.wordpress.com/ ) introduced MT in
> Processing and was completed by Alexandre Bruy (if I well remember it
> would be available at least in processing master)
> Nyall Dowson is working in a QgsTaskManager and relative QgsTask class
> ( https://www.youtube.com/watch?v=7pXBZtWYFJc ) and probably Processing
> and Task Manager will converge in a while.
> other than this you always create a plugin that run it's python
> process using all cores you want as stated by Nicolas Cadieaux... you
> should only have a lot of care using qgis classes, most of them are
> not thread safe in this moment.
> regards
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli > * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli > * GitHub: https://github.com/luipir > * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis > **************************************************************************************************
> On 13 May 2016 at 21:29, Elstermann, Mike < [hidden email] > wrote:
>> I have found the click for use more processor cores for rendering,
>> but how can QGIS use more processor cores for geoprocessing? My Mac use only
>> one of four cores :-(
>> Best regards
>> mikeE., The geoObserver.
>> Qgis-user mailing list
>> [hidden email]
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Use-all-cores-for-geoprocessing-tp5266295p5266615.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Use-all-cores-for-geoprocessing-tp5266295p5266644.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160516/2fa92a62/attachment.html>
