[Qgis-user] Local variables in field calculator
Matthias Kuhn
matthias at opengis.ch
Mon May 16 14:15:26 PDT 2016
On 05/16/2016 11:08 PM, Nyall Dawson wrote:
> On 17 May 2016 at 00:02, Nelson A. de Oliveira <naoliv at gmail.com> wrote:
>> Is it possible to use local variables in the field calculator?
>> For example, suppose I need to calculate the same maximum value with
>> "max(a lot of parameters)" in multiple places.
>> To avoid the same repeated expression (and also to avoid a possible
>> mistake in one of them), is there a way to create a local variable
>> with this result and then use it anywhere else in the same field
>> calculator code?
> No - that's not possible yet.
> Nyall
There is a workaround hack available that /may/ make sense in some
situations.
You can define it as a layer variable:
my_max_exp = max ( a lot of parameters )
And in the expression itself reference it as
eval( @my_max_exp )
Matthias
>> Thank you!
>> Best regards,
>> Nelson
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
