[Qgis-user] Classification from a CSV
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri May 20 05:46:06 PDT 2016
If you absolutely need a x and z, add the two Columns to the CSV and add dummy data. You can use WKT format or just value. That can be imported as a csv. You can save it after in another format like shp if you need it.
Nicolas
On May 19, 2016 12:06, "Lene Fischer [via OSGeo.org]" <ml-node+s1560n5267247h18 at n6.nabble.com> wrote:
No I can´t join, because there are no data in the project yet. We are setting up a project and need to append 45 different classifications for one layer.
regards
Lene Fischer
Associate Professor
Department of Geosciences and Natural Resource Management
University of Copenhagen
MOB +45 40115084
[hidden email]
Fra: Qgis-user [mailto: [hidden email] ]
På vegne af Nicolas Cadieux
Sendt: 19. maj 2016 16:54
Til: [hidden email]
Emne: Re: [Qgis-user] Classification from a CSV
Can you join the CSV to your layer using the "joins" function?
Nicolas
On May 19, 2016 09:49, "Lene Fischer [via OSGeo.org]" < [hidden email] > wrote:
Is there a workaround to import classification values into Style>classification dialog.
I have 45 values in a db table and want to add these into this dialog.
I don´t have any features in the table.
Regards
Lene Fischer
Qgis-user mailing list
<a href="/user/SendEmail.jtp?type=node&node=5267213&i=0">[hidden email]
List info:
http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe:
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Classification-from-a-CSV-tp5267213.html
To start a new topic under Quantum GIS - User, email
[hidden email]
To unsubscribe from Quantum GIS - User, <a href="<a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;unsubscribe_by_code&amp;node&#61;4125267&amp;code&#61;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&#61;&#61;">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
here.
<a href="<a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;macro_viewer&amp;id&#61;instant_html%21nabble%3Aemail.naml&amp;base&#61;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&amp;breadcrumbs&#61;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml">http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml"
style="font:9px serif">NAML
View this message in context:
Re: Classification from a CSV
Sent from the
Quantum GIS - User mailing list archive at Nabble.com.
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
http://osgeo-org.1560.x6.nabble.com/Classification-from-a-CSV-tp5267213p5267247.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Classification-from-a-CSV-tp5267213p5267430.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160520/ca21af5c/attachment.html>
