[Qgis-user] GEOS projection adding graticules produce some error
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed May 25 04:43:30 PDT 2016
I don't use that projection but make sure the file and the project are saved in the same projection. Sometimes, reprojection on the fly does that.  You can also try creating a spatial index.
Hope this helps
Nicolas
On May 25, 2016 4:17 AM, "chun-chieh chao [via OSGeo.org]	" <ml-node+s1560n5268096h37 at n6.nabble.com> wrote:
	Hi, I'm using QGIS 2.14.0 32bit and 64bit
Windows versions. I want to plot coastline and graticules shapefile over
himawari-8 geostationary satellite image setting GEOS projection. But
some error happen (please see http://i.imgur.com/s1XANv5.png ). I don't know how to resolve
those. 1) draw some extra lines out of the earth.2) missing a longitude
line around 180E or 180W. Regards, chun-chieh chao
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/GEOS-projection-adding-graticules-produce-some-error-tp5260247p5268096.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/GEOS-projection-adding-graticules-produce-some-error-tp5260247p5268143.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160525/482f3564/attachment.html>
