[Qgis-user] Very long sql in postgres layer definition
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu May 26 01:20:36 PDT 2016
Maybe it's easier to create a view on the DB and load that?
Bernhard
Am 26.05.2016 um 09:52 schrieb Samuel Ingarfield:
> Hi Bernhard;
> I can load the layer using an identical query in the DB manager sql window.
> Yes, r.id is a unique key.
> Sam.
> On Thu, May 26, 2016 at 3:37 PM, Bernhard Ströbl <bernhard.stroebl at jena.de>
> wrote:
>> Can you load it via the "add PostGIS layer" button?
>> Is r.id a suitable key (unique)?
>> Bernhard
>> Am 26.05.2016 um 09:33 schrieb Samuel Ingarfield:
>>> Hi All,
>>> I'm trying to load a postigs layer via python which is defined by a very
>>> long sql query. It seems that Qgis is truncating the query (which
>>> obviously
>>> causes it to fail). Has anyone come across this before and come up with a
>>> solution? Or am I loading the layer incorrectly?
>>> There is an unanswered question on stackexchange regarding this:
>>> http://gis.stackexchange.com/questions/162409/how-to-load-layers-from-postgres-using-select-statement
>>> My python code is very simple:
>>> sql = 'a very long query'
>>> uri=QgsDataSourceURI()
>>> uri.setConnection(host,"5432",dbname,user,passwd)
>>> uri.setDataSource("",sql,"geom","","r.id")
>>> vlayer = QgsVectorLayer(uri.uri(),"layer_name","postgres")
>>> QgsMapLayerRegistry.instance().addMapLayer(vlayer)
>>> The debug log shows the following:
>>> qgsmessagelog.cpp(45) : (QgsMessageLog::logMessage) [1ms]
>>> 2016-05-26T15:16:14 PostGIS[1] NOTICE: NOTICE: identifier "...long query
>>> here..." will be truncated to "...truncated query here..."
>>> 2016-05-26T15:16:14 PostGIS[1] Erroneous query: ...etc
>>> Any help would be great.
>>> Sam.
__________ Information from ESET Mail Security, version of virus signature database 13547 (20160526) __________
The message was checked by ESET Mail Security.
http://www.eset.com
