[Qgis-user] Is QGIS showing the records with geometry NULL
Andrea Peri
aperi2007 at gmail.com
Thu May 26 06:53:36 PDT 2016
Hi Jukka,
yes is exactly this the question.
The QGIS don't show any record with null geometry so is impossible for
me to add a geometry to it. Or delete it definitivelly.
But the record with null geometry is however saved when I export the
shapefile from qgis.
So the QGIS show me 14 records but export a shapefile with 16 records
(2 records has null geometry).
So when load it in a spatialite or on a postgis environment or open it
using another GIS like arcview3 from esri.
I see this two more records with null geometry.
AFAIK this is a chaotic situation for who work using qgis and produce
a shapefile to distribute to other users that has other gis softwares.
A.
2016-05-26 10:24 GMT+02:00 Jukka Rahkonen <jukka.rahkonen at maanmittauslaitos.fi>:
> Nicolas Cadieux <nicolas.cadieux at ...> writes:
>> Hi,
>> Is it possible that the 2 missing records were deleted in another GIS?
> There is an issue with deleting records in shape file as there are many ways
> to do that. If the record were deleted in another GIS, they may show up (or
> not) in another software. Could that be it...
>> Nicolas
> Hi,
> I suppose that Andrea means a valid situation with real existing features
> which just do not have geometry. They are valid in shapefiles but many GIS
> software have difficulties in dealing with them. Naturally they cannot be
> showed on the map and spatial queries can't find them but they should be
> found from attribute view and be editable there.
> -Jukka Rahkonen-
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
