[Qgis-user] Very long sql in postgres layer definition
Samuel Ingarfield
sam at sjfi.net
Thu May 26 17:31:05 PDT 2016
Ah, perfect. Enclosing the query in brackets did the trick.
Thanks Jürgen!
Cheers;
Sam.
On Thu, May 26, 2016 at 8:48 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Samuel,.
> On Thu, 26. May 2016 at 15:33:44 +0800, Samuel Ingarfield wrote:
> > I'm trying to load a postigs layer via python which is defined by a very
> > long sql query. It seems that Qgis is truncating the query (which
> obviously
> > causes it to fail). Has anyone come across this before and come up with a
> > solution? Or am I loading the layer incorrectly?
> Did you enclose the query in ()?
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160527/3f958593/attachment.html>
