[Qgis-user] Auto-fill id in attribute table when creating a feature
Neumann, Andreas a.neumann at carto.net
Tue May 31 05:04:00 PDT 2016
Hi Simon,
It is a bit data provider dependent. For many data providers (e.g.
Postgis, SpatiaLite, Geopackage) you just don't fill in this value (or
better set the edit widget to "read only") - provided that the database
has a sequence defined for the primary key column. The values are filled
in when saving the data. In 2.16 there is a new mode for PostgreSQL to
immediately get the id value (experimental).
What data format are you using?
Greetings,
Andreas
On 2016-05-31 13:43, Simon Muirhead wrote:
> Hi, I am new to QGIS, coming from ARCGiS. I was wondering when creating a new feature in a shape file, QGIS asks to fill in the id in the attribute table for every feature created. Is there anyway to have this done automatically like ARCGiS does?
> Regards, Simon Muirhead
> Written from my Nexus 6P so don't expect Tolstoy.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160531/ff27567c/attachment.html>
