[Qgis-user] Auto-fill id in attribute table when creating a feature
Karl-Magnus Jönsson Karl-Magnus.Jonsson at kristianstad.se
Tue May 31 06:41:06 PDT 2016
OK. Maybe not. But are you not interested in adding attribute values to the features you can set that the attribute form doesn’t show after adding features. Look in the top of section digitizing in the options dialog.
http://docs.qgis.org/2.8/en/docs/user_manual/introduction/qgis_configuration.html#options
Karl-Magnus Jönsson
Från: Simon Muirhead [mailto:simon at simsurf.com.au]
Skickat: den 31 maj 2016 15:27
Till: Karl-Magnus Jönsson
Ämne: Re: SV: [Qgis-user] Auto-fill id in attribute table when creating a feature
Hi Karl, it won't let you create a shape file without at least one field in the attribute table.
Regards, Simon Muirhead
Written from my Nexus 6P so don't expect Tolstoy.
On 31 May 2016 23:19, "Karl-Magnus Jönsson" <Karl-Magnus.Jonsson at kristianstad.se<mailto:Karl-Magnus.Jonsson at kristianstad.se>> wrote:
Hi!
Do you really need the ID field in the shapefile? If not you can drop it, hide it or ignore it and it works anyway. If you need a counter as primary key consider using another data provider suggested by Andreas.
Karl-Magnus Jönsson
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] För Neumann, Andreas
Skickat: den 31 maj 2016 14:04
Till: Simon Muirhead
Kopia: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Ämne: Re: [Qgis-user] Auto-fill id in attribute table when creating a feature
Hi Simon,
It is a bit data provider dependent. For many data providers (e.g. Postgis, SpatiaLite, Geopackage) you just don't fill in this value (or better set the edit widget to "read only") - provided that the database has a sequence defined for the primary key column. The values are filled in when saving the data. In 2.16 there is a new mode for PostgreSQL to immediately get the id value (experimental).
What data format are you using?
Greetings,
Andreas
On 2016-05-31 13:43, Simon Muirhead wrote:
Hi, I am new to QGIS, coming from ARCGiS. I was wondering when creating a new feature in a shape file, QGIS asks to fill in the id in the attribute table for every feature created. Is there anyway to have this done automatically like ARCGiS does?
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160531/deb05d95/attachment.html>
