[Qgis-user] New release -2.18 - Polar projection graticules
Lester Anderson arctica1963 at gmail.com
Thu Nov 3 03:43:38 PDT 2016
Thanks for the pointer Nathan. I did raise the issue earlier, so not
sure if that was taken on board.
On 3 November 2016 at 10:41, Lester Anderson <arctica1963 at gmail.com> wrote:
> The previous post highlighting this issue was:
> https://lists.osgeo.org/pipermail//qgis-user/2016-June/036527.html
> On 3 November 2016 at 10:35, Lester Anderson <arctica1963 at gmail.com> wrote:
>> Hello,
>> Just thought I would see if the new version has improved (fixed) the
>> issue with graticules in map composer for Polar projections.
>> The latitude lines would be visible straightline segments (very
>> obvious) and longitide lines would be missing in places.
>> Posted about this issue a while back, so wanted to check and see if
>> any changes have been done in this respect (quite important for Polar
>> mapping!).
>> Thanks
>> Lester
