[Qgis-user] Corporate Users
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Sat Nov 5 11:29:56 PDT 2016
Hi Richard -
Be my guest, knock yourself out, go ahead - It's always nice if other
people can use the work that was invested in this project ;-)
I haven't too much time to spare the next month or two, so you have my
full permission to write an article about this method. I can of course
help you by "proof" reading the article before publishing if you find it
necessary.
And I agree fully with you about using an ini file based approach to
save settings for Qgis :-)
Regards
Bo Victor
Den 05/11/16 kl. 10:06 skrev Richard Duivenvoorde:
> Bo: thanks for this great write up!
> Is it ok if you/I write a small article on blog.qgis.org or qgis.nl or
> qgis.dk and point to the english version of your writeup?
> https://github.com/Frederikssund/Alternativ-QGIS-installation/blob/master/Readme%20-%20english.md
> I think a lot of organisations/windows system admins will be greatfull
> to you!
> By the way, in my view the default storing mechanism of settings should
> be ini file based anyway! I'll try to bring this up on the dev list again.
> Regards,
> On 04-11-16 15:36, Bo Victor Thomsen wrote:
>> We ( as in the municipality of Frederikssund, Denmark) has a medium size
>> enterprise installation of Qgis 2.8 at around 100 local installations of
>> Qgis 2.8 in a Windows-7 64 bit environment. There is no significant
>> problems with this installation.
>> The largest problem by far was to sift through a mountain sized heap of
>> tab files from an older installation of MapInfo and determine which
>> should be restructured, cleaned and imported to our MS-SQLServer based
>> database environment.
>> In the near future - probably a month - We are doing a roll out of Qgis
>> 2.18 to around 250 Windows workstations using this method:
>> "https://github.com/Frederikssund/Alternativ-QGIS-installation" (don't
>> worry about the Danish readme.md - there is documentation in English too
>> If you have a large amount of different layers / tables, I suggest you
>> take a look at the "QLR Browser" plugin. This plugin provides an immense
>> help to structure user access to a large number of layers:
>> And of course: Use a database to store your data. Preferably
>> Postgres/PostGIS (Open source and IMHO the most powerful spatial
>> database), but MS-SQL Server or Oracle will do If you don't have a
>> choice regarding database systems.
>> Regards
>> Bo Victor Thomsen
>> GIS & Database specialist
>> Municipality of Frederikssund
>> Den 04/11/16 kl. 04:24 skrev Grant Boxer:
>>> I am using QGIS in a single stand-alone situation and I was wondering
>>> what examples there are of medium to large corporations using QGIS as
>>> their GIS platform and what issues you need to be aware of in large
>>> multi-user QGIS situations?
>>> Grant Boxer
>>> Perth, Western Australia
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
