[Qgis-user] QGIS server: configuration of grid shift files for datum conversions
Schmid Andreas Andreas.Schmid at bd.so.ch
Mon Nov 7 03:15:51 PST 2016
Hi Andreas
I did some investigation and found the following answers to your questions:
> Is the id 100001 for the swiss datum transformation stable?
> Are those .gsb file names hard coded somewhere?
I suppose the id is stable. The id and the .gsb file names seem to be hard coded in the srs.db template. Apparently the id for CHENYX06a.gsb has been defined in commit https://github.com/qgis/QGIS/commit/3465c3eb509b9285f0b7d99129dcbaad84463771
> The table tbl_datum_transformation does not contain any references to the .gsb files. How does QGIS find those files?
QGIS seems to look for the .gsb files in the directory where Proj.4 stores them: /usr/share/proj (I see you figured this out too)
Thanks a lot for updating the documentation.
Btw. now I guess that it’s possibly not even necessary to run crssync (opposed to what I wrote earlier).
Andy
Von: Neumann, Andreas [mailto:a.neumann at carto.net]
Gesendet: Freitag, 28. Oktober 2016 16:56
An: Schmid Andreas
Cc: 'richard at duif.net'; 'QGIS User List'
Betreff: Re: [Qgis-user] QGIS server: configuration of grid shift files for datum conversions
I was able to fix the crash by naming the .gsb files EXACTLY like Andy wrote below - my name before was chenys06a.gsb. After I created a symblink to CHENYX06a.gsb the crash was gone.
This looks really strange. Are thoses .gsb file names hard coded somewhere? Quite a mystery ...
Andreas
On 2016-10-28 16:45, Neumann, Andreas wrote:
Hi Andy,
Thank for these very precise instructions.
I was able to do the same on CentOS 7 with only very minor differences (probably because I self-compile QGIS server).
I think this information should be added to the QGIS user manual, in the server section. I created a pull request: https://github.com/qgis/QGIS-Documentation/pull/1481
fyi: i get a server crash when I use a request in EPSG:2056, project done in EPSG:21781 - still investigating what the reason is ...
Thanks a lot - very useful information!
Andreas
On 2016-10-24 11:09, Schmid Andreas wrote:
At Kanton Solothurn we had the same requirement. And we did not want to fiddle with the original proj.4 definition files. So we paid Sourcepole for solving this directly in QGIS Server (https://github.com/qgis/QGIS/commit/70863ecaf0ccfcb538e3892af4b528304b21a0a2).
This is how it works under Ubuntu:
* Place those CHENYX06a.gsb and CHENYX06_etrs.gsb in /usr/share/proj (probably in our case only CHENYX06a.gsb is actually needed)
* If QGIS Server was installed before placing the .gsb files, run /usr/lib/qgis/crssync (or run it anyway)
* In /etc/apache2/mods-enabled/fcgid.conf place the following additional option:
InitialEnv DEFAULT_DATUM_TRANSFORM=EPSG:21781/EPSG:2056/100001/-1;EPSG:2056/EPSG:21781/-1/100001
The meaning of this option is: when your .qgs is in EPSG:21781 and the WMS request is in EPSG:2056, then use datum transformation 100001; when your .qgs is in EPSG:2056 and the WMS request is in EPSG:21781, then use datum transformation 100001 as well, but use it the other way round.
The datum transformation code 100001 can be looked up in /usr/share/qgis/resources/srs.db. Look at attribute coord_op_code of table tbl_datum_transform.
Regards,
Andy
-----Ursprüngliche Nachricht-----
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] Im Auftrag von Richard
Duivenvoorde
Gesendet: Montag, 24. Oktober 2016 10:01
An: Neumann, Andreas
Cc: QGIS User List
conversions
On 2016-10-24 06:23, Neumann, Andreas wrote:
I have to configure QGIS server to properly handle grid shift files.
In Switzerland we need to offer "old" and "new" coordinates (different
datums) at the same time with our services and the conversion needs to
be done with grid shift files or tin based interpolation.
I know that I have to copy the CHENYX06a.gsb file to my proj lib, e.g.
/usr/local/shar/proj  - but how can I make QGIS Server to actually use
this file? I assume that I need to copy an additional config file or
SRS/grid shift file combinations to QGIS server and/or specify an
environment variable - right?
Are there any resources explaining how I can configure QGIS server to
make use of these grid shift files?
Thank you for any pointers!
Hi Andreas,
funny, in NL we just had a discussion about how to handle different
available datum transformation too last week...
we also recently got a grid shift file to better handle datum
transformation and I found this post of Sourcepole:
http://blog.sourcepole.ch/2014/02/18/ntv2-transformations-with-qgis/
Which I think answers your question (at least for the desktop side)
But from a mini presentation from somebody from our National Cadastre, I
actually draw the conclusion that the way QGIS represents CRS's is too
narrow/not complete...
Please correct me if I'm wrong, but a lot of 'On The Fly'-reprojections
actually need 2(!) proj configurations/steps:
- the projection parametes (mostly available in the epsg database)
- the datum transformation parameters (these is the 'towsg84...'-part,
AND only needed when you do an actual datum transformation, PARTLY
The last part can either be a list of parameters (to calculate it) OR
(as in your case and in the dutch preferred case) a grid shift file (as
proj can only handle one of these).
SO: for example for certain crs's (in QGIS the dutch one is called
epsg:28992) there is actually a SET of combinations available: the
projection and 4 or 5 transformations
(http://pix.toile-libre.org/upload/original/1477238061.png),
QGIS actually picks one (from qgis.db) of these and present them to the
user as THE epsg:28992 crs, while in our case this is actually not the
best fit, and in your case you actually want to pick two!
I understood that in ArcGIS, the user actually every time is presented
with a 'pick the right datum transformation' dialog as soon as the data
needs a datum transformatio. As a draw back: making it more difficult
for new users to pick the right one, BUT on the positive side making it
easier to pick the right projection/datumtransformation pair!
So what about using both worlds:
- in the qgis.db / crs table NOT use the projection-name as
crs-identifier (so NOT epsg:28992), BUT the combination of projection
AND datumtransformation, so in our case (28992_4833, 28992_15934, or
epsg28992_epsg4833, epsg28992_qgis0001 to be able to handle
projection/transformation combinations not available in the epsg db)
- and instead of current possibility to have a 'check'-box to have the
'select datum transformation' popup we make this available in the
'choose crs'-dialog with a button, and then 'remember' the last used
crs's (in which a crs is NOT only the projection anymore but a
projection/transformation combi)
IF QGIS starts using this combinations AND proj/gdal will ship all
gridfiles towgs-paramters etc etc, this will become a better world :-)
Does this make sense? Do others get excited from this idea too?
Regards,
Richard Duivenvoorde
ps about providing the gridfiles, I urge our national Kadaster to make
it available as treu open geodata, that is without a copyright
disclaimer, so it can be picked up by Debian and other distro's.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161107/0e1e2614/attachment.html>
