[Qgis-user] Combining modern maps with old maps
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Nov 10 05:43:56 PST 2016
As an archaeologist, I do that a lot. You will need to scan the map to create a .tiff. The you use the qgis georeferencing plugin to place the map in the correct spot.
http://www.qgistutorials.com/en/docs/georeferencing_basics.html
This should help. Also look at the qgis documentation. http://docs.qgis.org/2.14/en/docs/user_manual/
If you overlap polygons or two rasters, play with the layer rendering and transparency found in the layer properties.
Cheers
Nicolas
> Le 10 nov. 2016 à 06:22, Pat Hin [via OSGeo.org] <ml-node+s1560n5295134h15 at n6.nabble.com> a écrit :
> Hello guys
> i am a private researcher who is analyzing where some former old
> buildings has been
> most surely been located.
> For that of course i have sometimes just a very old map (sometimes a
> picture or a scan).
> How would be the best way to "overlap" this with a modern map like OSM.
> I am sure i have to create two layers and the layer for the modern map
> is easily to do
> with the plugins.
> But how to process the "old" map the best way: would do you recommend to do?
> many thanks
> pat
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Error-when-running-a-simple-raster-filter-tp5295132p5295134.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-when-running-a-simple-raster-filter-tp5295132p5295146.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161110/1cda7793/attachment.html>
