[Qgis-user] Spatial resampling of a point vector layer using QGIS
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri Nov 11 05:16:22 PST 2016
Hi Giacomo.
You can access gdal_grid from qgis. (Raster menu).  Use the moving average algorithm.
 If it's not there, you may need to modify the gdal command line by pressing the yellow pencil.
http://www.gdal.org/gdal_grid.html#gdal_grid_algorithms_average
Nicolas
> Le 10 nov. 2016 à 17:48, Giacomo Fontanelli-2 [via OSGeo.org] <ml-node+s1560n5295232h53 at n6.nabble.com> a écrit :
> down vote
> favorite
> I have a vector layer with points located on a regular square grid of 2Km. The layer has a column with a numeric value (crop yield) for each point.
> I would like to resample the vector to a grid of 1Km, and the new points should have the crop yield value represented by the average of the 4 points surrounding.
> I would like o use QGis.
> Thank you for your suggestions
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Spatial-resampling-of-a-point-vector-layer-using-QGIS-tp5295232.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Spatial-resampling-of-a-point-vector-layer-using-QGIS-tp5295232p5295336.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161111/38955db5/attachment.html>
