[Qgis-user] MapInfo to QGIS style generator ; error message
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Nov 15 17:48:21 PST 2016
I have not used this in a while now but the first step, if I remember is to export the object style from the .tab into a new field.
This is done in Mapinfo.  Have you done this step?
Nicolas
> Le 15 nov. 2016 à 19:37, dandrigo [via OSGeo.org] <ml-node+s1560n5295947h18 at n6.nabble.com> a écrit :
> Good morning,
> I'm working on windows 10 with mapinfo 16, qgis 2.16.3.
> I tried to use the usefull following plugin called "MapInfo to QGIS style generator":
> https://github.com/NathanW2/MapInfo-to-QGIS-style-generator/wiki/Using-MapInfo-to-QGIS-style-generator.
> But when i launch this following command via osgeo4w shell :
> python mapinfoToQgis.py F:\temp\commerces.TAB F:\temp\out.qml -c ID_SYMBOLOGIE --UseMapInfo
> An error message appears. I send you the attachment showing the error message.
> Could you throw light for me regarding the meaning of the error message and could youhow to help me in order to find a solution?
> In advance, thank you very much.
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/MapInfo-to-QGIS-style-generator-error-message-tp5295947.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapInfo-to-QGIS-style-generator-error-message-tp5295947p5295949.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161115/7d683cbf/attachment.html>
