[Qgis-user] Editing a Postgis view
Nyall Dawson
nyall.dawson at gmail.com
Wed Nov 16 10:22:35 PST 2016
On 17 Nov 2016 12:54 AM, "Carlo A. Bertelli (Charta s.r.l.)" <
carlo.bertelli at gmail.com> wrote:
> Ciao Andrea,
> by default Postgresql views are read only. Even the simplest view made in
Postgresql needs a rule to be updated.
That's not quite correct. Recent versions of postgres make simple views
editable.
See
https://www.depesz.com/2012/12/11/waiting-for-9-3-support-automatically-updatable-views/
Nyall
After writing a statement for a view, just take the habit of writing the
rules for insert, update, delete.
> Please read the chapter on the Rule System in the Postgresql Reference
Manual for the instructions.
> c
> Message: 6
> Date: Wed, 16 Nov 2016 09:39:23 +0100
> From: Andrea Peri <aperi2007 at gmail.com>
> To: Matthias Kuhn <matthias at opengis.ch>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Editing a Postgis view
> Message-ID:
> <CABqTJk8Bo7fs6qOG=MhO9N50qO5L+JkXAOAgik=
tUGWwcKd-WA at mail.gmail.com>
> Content-Type: text/plain; charset=UTF-8
> Hi Matthias,
> thx for response.
> So the trouble is in my db.
> Now I try to understand better why it is not working.
> This is my actual try test:
> create table schemaapp.repository(
> ID serial primary key NOT NULL,
> UUID varchar(50) NOT NULL,
> PROGETTO varchar(9) NOT NULL,
> PROCEDIMENTO text NOT NULL,
> GEOMETRIA1 geometry(MULTIPOINT, 3003)
> create view schemaapp.v_repository_point as
> select
> a.id as id,
> a.uuid as uuid,
> a.progetto as progetto,
> a.procedimento as procedimento,
> a.geometria1 as geometria
> from
> schemappa.repository_wfs as a
> where
> a.geometria1 is not null;
> I will know if discover something.
> thx again.
> 2016-11-16 8:54 GMT+01:00 Matthias Kuhn <matthias at opengis.ch>:
> > Hi Andrea,
> > It works here.
> > Do you have an instead of insert rule written on your view?
> > It works for me this way (but my views are too complicated for postgres
> > to create default insert rules by default anyway).
> > You can also try to alter your view with a default value for the column
> > in question.
> > Best regards
> > Matthias
> > On 11/16/2016 08:15 AM, Andrea Peri wrote:
> >> Hi,
> >> I'm having some trouble to edit a postgis view using qgis.
> >> The view is a simple:
> >> select list-of-field from table1;
> >> And the table1 is a table with a Primary key on a serial type field.
> >> I add the first record and all was ok. The commit too.
> >> When go to add the second record.
> >> I start to have trouble.
> >> The qgis report my always a constraint violation of the pk.
> >> I try to leave the pk field empty, or try to fill it with a value.
> >> No solution work.
> >> So my question is if is confirmed that qgis (I use the 2.18) version)
> >> is working in editing with a postgis view .
> >> Thx.
> >> A.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161117/fb3a3b35/attachment.html>
