[Qgis-user] Map Composer
DelazJ delazj at gmail.com
Mon Nov 21 14:16:45 PST 2016
The answer is here:
http://docs.qgis.org/2.14/en/docs/user_manual/print_composer/composer_items/composer_map.html;
change the map property from 'Rectangle' to 'Render'.
HTH,
Harrissou
2016-11-21 21:56 GMT+01:00 RMG <reikogoodwin at gmail.com>:
> Hi,
> I am using Nødebo on El Capitan. When I reopen a saved project in which a
> map has been composed previously, the map 0 simply refuses to appear,
> although when I click on "save the image" it saves the image, but because
> it is invisible on the Map composer, editing is difficult. I click on
> Update preview, draw map canvas items, set rotate to 0, unlock the layer,
> unlock the item, but the map 0 simply won't become visible. The message
> on the map area says "Map will be printed here". What is the solution to
> this problem?
> Thanks for your attention.
> Reiko M. Goodwin
> facebook.com/GuenonConservationCommunity/
> Statement of Confidentiality: The information contained in this electronic
> message and any attachments to this message are intended for the exclusive
> use of the addressee(s) and may contain confidential or privileged
> information. If you are not the intended recipient, please notify
> reikogoodwin at gmail and destroy all copies of this message and any
> attachments.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161121/123b675e/attachment.html>
