[Qgis-user] Python error on startup
Stephen Ban
stephen at cpawsbc.org
Tue Nov 22 11:38:01 PST 2016
I recently started getting an error message when launching QGIS. I can't
pinpoint exactly when it started happening, but I'm pretty sure it must be
related to a recent install of Python when I had both Python 2.7 and 3.5
installed. I also have ArcGIS on my machine, so that was the only Python
version installed for awhile. I then installed Python 3.5 to do some
testing, but have since uninstalled it so the only remaining standalone
Python version is ArcGIS's 2.7. I've purged any extraneous Python
environment variables and cleaned the Windows registry to no effect. I'm
running Windows 10 64-bit edition, and have always installed the 64-bit
versions of QGIS.
I was originally running GQIS 2.16.1, then uninstalled it and installed QGIS
2.18. Both versions give me the same error message on startup: "Python
error: Couldn't load plugin 'processing' See message log (Python Error) for
more details." The Python message log contains the following:
"1 Traceback (most recent call last):
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python\qgis\utils.py", line 308, in
loadPlugin
__import__(packageName)
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python\qgis\utils.py", line 607, in
_import
mod = _builtin_import(name, globals, locals, fromlist, level)
File
"C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\__init__.py",
line 29, in <module>
from processing.tools.general import * # NOQA
_import
File
"C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\tools\general.
py", line 31, in <module>
from processing.core.Processing import Processing
_import
File
"C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\core\Processin
g.py", line 55, in <module>
from processing.algs.qgis.QGISAlgorithmProvider import QGISAlgorithmProvider
_import
File
"C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\algs\qgis\QGIS
AlgorithmProvider.py", line 109, in <module>
from .RasterLayerStatistics import RasterLayerStatistics
_import
File
"C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\algs\qgis\Rast
erLayerStatistics.py", line 36, in <module>
from processing.tools import raster
_import
File
"C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\tools\raster.p
y", line 29, in <module>
import numpy
_import
File
"C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\__init__
.py", line 180, in <module>
from . import add_newdocs
_import
File
"C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\add_newd
ocs.py", line 13, in <module>
from numpy.lib import add_newdoc
_import
File
"C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\lib\__in
it__.py", line 8, in <module>
from .type_check import *
_import
File
"C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\lib\type
_check.py", line 11, in <module>
import numpy.core.numeric as _nx
_import
File
"C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\core\__i
nit__.py", line 14, in <module>
from . import multiarray
_import
ImportError: DLL load failed: %1 is not a valid Win32 application."
Any help or advice on resolving this error would be appreciated.
Stephen
Stephen Ban, Ph.D., RPBio.
National Ocean Spatial Analysis Manager
Canadian Parks and Wilderness Society
#410-698 Seymour Street, Vancouver, B.C. V6B 3K6
Tel: 604 685-7445 ext. 30
Fax: 604 629-8532
Email: <mailto:stephen at cpawsbc.org> stephen at cpawsbc.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161122/e9eb3624/attachment.html>
