[Qgis-user] Python error on startup
    Stephen Ban
    stephen at cpawsbc.org
    Tue Nov 22 13:06:30 PST 2016
Oddly, I was able to fix it by simply reinstalling/upgrading numpy in my existing Python 2.7 install.
It doesn’t make any sense to me, but it works.
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Nicolas Cadieux
Sent: November 22, 2016 12:22 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Python error on startup
You need to change your default Python to the one that qgis uses.  You can change that in the windows environment variables
Nicolas
Le 22 nov. 2016 à 14:38, Stephen Ban [via OSGeo.org <http://OSGeo.org> ] <[hidden email]> a écrit :
I recently started getting an error message when launching QGIS. I can’t pinpoint exactly when it started happening, but I’m pretty sure it must be related to a recent install of Python when I had both Python 2.7 and 3.5 installed. I also have ArcGIS on my machine, so that was the only Python version installed for awhile. I then installed Python 3.5 to do some testing, but have since uninstalled it so the only remaining standalone Python version is ArcGIS’s 2.7. I’ve purged any extraneous Python environment variables and cleaned the Windows registry to no effect. I’m running Windows 10 64-bit edition, and have always installed the 64-bit versions of QGIS.
I was originally running GQIS 2.16.1, then uninstalled it and installed QGIS 2.18. Both versions give me the same error message on startup: “Python error: Couldn’t load plugin ‘processing’ See message log (Python Error) for more details.” The Python message log contains the following:
“1 Traceback (most recent call last):
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python\qgis\utils.py", line 308, in loadPlugin
__import__(packageName)
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python\qgis\utils.py", line 607, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\__init__.py", line 29, in <module>
from processing.tools.general import * # NOQA
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\tools\general.py", line 31, in <module>
from processing.core.Processing import Processing
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\core\Processing.py", line 55, in <module>
from processing.algs.qgis.QGISAlgorithmProvider import QGISAlgorithmProvider
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\algs\qgis\QGISAlgorithmProvider.py", line 109, in <module>
from .RasterLayerStatistics import RasterLayerStatistics
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\algs\qgis\RasterLayerStatistics.py", line 36, in <module>
from processing.tools import raster
File "C:/PROGRA~1/QGIS21~1.1/apps/qgis/./python/plugins\processing\tools\raster.py", line 29, in <module>
import numpy
File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\__init__.py", line 180, in <module>
from . import add_newdocs
File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\add_newdocs.py", line 13, in <module>
from numpy.lib import add_newdoc
File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\lib\__init__.py", line 8, in <module>
from .type_check import *
File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\lib\type_check.py", line 11, in <module>
import numpy.core.numeric as _nx
File "C:\Users\steph\AppData\Roaming\Python\Python27\site-packages\numpy\core\__init__.py", line 14, in <module>
from . import multiarray
ImportError: DLL load failed: %1 is not a valid Win32 application.”
Any help or advice on resolving this error would be appreciated.
Stephen
Stephen Ban, Ph.D., RPBio.
National Ocean Spatial Analysis Manager
Canadian Parks and Wilderness Society
#410-698 Seymour Street, Vancouver, B.C. V6B 3K6
Tel: 604 685-7445 ext. 30
Fax: 604 629-8532
Email: [hidden email]
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
  _____
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Python-error-on-startup-tp5297007.html
To start a new topic under Quantum GIS - User, email [hidden email]
To unsubscribe from Quantum GIS - User, click here.
 <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> NAML
  _____
View this message in context: Re: Python error on startup <http://osgeo-org.1560.x6.nabble.com/Python-error-on-startup-tp5297007p5297009.html>
Sent from the Quantum GIS - User mailing list archive <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>  at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161122/23219977/attachment.html>
