[Qgis-user] QGIS MBTiles
Stefan Löhr
loehr at topographics.de
Wed Nov 23 05:15:58 PST 2016
thanks for your fast answer.
I opened the dataset with "spatialite-gui.exe" and it seems to be
populated with a lot of tiles.
The minzoom and maxzoom entries in "metadata" are also present:
name value
format png
version 1.0.0
center 16.500071,63.322846,4
name doete
tags asdf
bounds -20.999853,37.645693,53.999995,89.000000
legend [....]
credits asdf
maxzoom 19
type overlay
attribution
minzoom 0
description ad
use_constraints asdf
The coordinates seem to be somewhat strange, but the rest looks ok.
The strange thing is:
It says maxzoom=19, but in the "tiles" table, there are only tiles up to
zoom-level 17.
Could that be the problem?
Stefan
Am 23.11.2016 um 13:55 schrieb Even Rouault:
> Stefan
> > when I try to add a raster layer based on a local MBTiles file in QGis
> > 2.14 I get this error:
> > "Nicht unterstütztes Datenformat: D:\Files\Testdata.mbtiles ist keine
> > unterstützte Rasterdatenquelle Cannot find min and max tile numbers"
> > Did someone successfully use MBTiles with QGis?
> Yes sure.
> This error messages comes from the underlying GDAL MBTiles driver.
> There is something in your dataset that it doesn't like. Either the
> driver isn't robust to this case, either the mbtiles isn't conformant.
> But hard to tell without access to the file.
> > Where is QGIS searching for the "min and max tile numbers"? Does it have
> > to be in one of the metadata tables?
> > Or is it somehow calcluated on the fly?
> It looks at the metadata table for 'minzoom' and 'maxzoom' entries. If
> not found, it then looks at the tiles table to query the min and max
> values of zoom_level.
> The error could occur if the MBTiles dataset is completely empty.
> Otherwise I'm not sure without inspecting it.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161123/a2b38dd3/attachment.html>
