[Qgis-user] Rules based style in QGIS 2.18.
Nyall Dawson
nyall.dawson at gmail.com
Wed Nov 23 15:22:53 PST 2016
On 22 November 2016 at 08:49, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 22 November 2016 at 07:36, Erik Heinz <eh0907-qgis at 42net.de> wrote:
>> Hi everyone,
>> I am having problems with some rule bases style definitions thad used to
>> work up to 2.16 but do not work in 2.18 any more. The elements in question
>> are simply not drawn. I could not figure out any logic in what does work
>> and what does not.
>> Are there any changes in rule syntax? Or removal of undocumented features?
>> I could not find any in the Changelog. Or should I suspect and report a bug?
>> I am back to 2.16.2 for the moment.
> Can you share your rule definitions?
Erik,
I've had a look and found the issue. One of your rules uses the expression:
boundary='administrative'
In 2.18 a new boundary(...) function was introduced, so this
expression is now flagged as an error (since it's trying to call a
function without passing any arguments). Changing the filter to:
"boundary"='administrative'
Makes it work again. Wrapping boundary in " " tells QGIS that you're
referring to a field name here, not the function of the same name. In
general it's good practice to always wrap field names in " "s to avoid
this situation.
Cheers,
Nyall
> Nyall
>> Best regards,
>> Erik
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
