[Qgis-user] QGis-Server 2.14 raises error reading project file on Ubuntu 16.04
Luí­s de Sousa luis.de.sousa at protonmail.ch
Mon Oct 3 08:20:25 PDT 2016
Dear all,
I installed QGis-Server 2.14 on Ubuntu 16.04 following the instructions on [this blog](http://www.paulshapley.com/2016/07/how-to-install-qgis-server-on-ubuntu.html?showComment=1475153231712#c4163641401127840252) [0]. The fgci on its own is responsive and correctly replying to a GetCapabilities request like:
http://localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
However, if I point the browser to a QGis project file, like:
http://localhost/cgi-bin/project/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
The response is an error:
<ServiceExceptionReport version="1.3.0"> <ServiceException code="WMS configuration error"> There was an error reading the project file or the SLD configuration </ServiceException> </ServiceExceptionReport>
Using directly the command line I get a different error message:
$ ./qgis_mapserv.fcgi "QUERY_STRING=SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities" QFSFileEngine::open: No file name specified Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment variable. Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment variable. Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP environment variable. Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment variable. Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP environment variable. Content-Length: 206 Content-Type: text/xml; charset=utf-8 <ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc"> <ServiceException code="Service configuration error">Service unknown or unsupported</ServiceException> </ServiceExceptionReport>
The Apache logs are clean. The error log is empty and the access log is reporting nothing unusual.
Are there any other logs I can look into? Any hints on what may be causing this error(s)?
Regards,
Luís
[0] http://www.paulshapley.com/2016/07/how-to-install-qgis-server-on-ubuntu.html?showComment=1475153231712#c4163641401127840252
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161003/1fe7cf34/attachment.html>
