[Qgis-user] plugin doesn't find exiftool executable
Alexander Bruy
alexander.bruy at gmail.com
Tue Oct 4 06:41:09 PDT 2016
It does. Now I see, you just do it wrong and without
reading documentation :-).
"ExifTool Config" field used to specify custom config
file, not executable. Path to executable file should be
configured in plugin settings.
Please check documentation at
https://github.com/NaturalGIS/geotag_and_import_photos/wiki
Hope this helps
2016-10-04 16:28 GMT+03:00 Reginald Carlier <Reginald.Carlier at ingelmunster.be>:
> Hi Alexander,
> The tool doesn't accept the folder as entry.
> Where should I change the settings?
> Regards,
> -----Oorspronkelijk bericht-----
> Van: Alexander Bruy [mailto:alexander.bruy at gmail.com]
> Verzonden: dinsdag 4 oktober 2016 15:08
> Aan: Reginald Carlier
> CC: qgis-user at lists.osgeo.org
> Onderwerp: Re: plugin doesn't find exiftool executable
> Hi Richard,
> you should specify just directory where exiftool.exe located, not full path to th executable file.
> Hope this helps.
> 2016-10-04 15:42 GMT+03:00 Reginald Carlier <Reginald.Carlier at ingelmunster.be>:
>> Hi Alexander,
>> I installed the plugin in QGIS 2.16.3.
>> When I run the ‘Import photos’ tool I point the ExifTool Config browse
>> button to the exiftool(-k).exe that I have downloaded from
>> http://www.sno.phy.queensu.ca/~phil/exiftool/index.html
>> I installed the windows executable.
>> When running the ‘Import photos’ tool it gives following error:
>> Can’t locate exiftool executable! Make sure it is installed and
>> available in PATH or alternatively specify path to binary in plugin
>> settings (which is what I did I think?)
>> Is there another place where I can set the plugin settings? Should I
>> rename exiftool(-k).exe to exiftool?
>> Regards,
> Alexander Bruy
Alexander Bruy
