[Qgis-user] How to enable GRASS7 in QGIS 2.16 on Mac?
Berns Buenaobra poormanphysics at gmail.com
Tue Oct 11 19:37:30 PDT 2016
As far as my experience brought me into using MAC OS for QGIS with GRASS or
GRASS alone - if your MAC OS X is El Capitan right now there is no solution
that exist and disabling the security feature is not a guarantee that it
will work with El Capitan - the developer's advise was to wait for newer
package for it.
Since upgrading to El Capitan - I cannot anymore use GRASS so I resort to
my Bootcamp WIndows partition and have it done everything in a QGIS Windows
version without a hitch or trouble.
Regards,
Berns B.
On Tue, Oct 11, 2016 at 11:14 AM, William Kyngesburye <woklist at kyngchaos.com
> wrote:
> Well, I don't see a problem with the build (linked libraries/binary
> images).  It looks like something got out of control, but it's too deep for
> me.  I'm not crashing in the browser or opening a GRASS layer.
> Are you sure it happens when you click a GRASS layer?  Try letting the
> browser sit for a while and see it QGIS eventually crashes.
> Does it happen with both raster and vector layers? or just one?
> Try closing the browser panel and opening again.
> Try closing the browser panel and loading the GRASS layer with drag-n-drop
> (very clunky) - for a raster the named file in the cellhd folder of the
> mapset, for a vector the head file in the named subfolder of the vector
> folder.  Oddly, I get a crash on rasters with this method, but not
> vectors.  This method names the layers added by the file names selected.
> Are there other kinds of data showing in the browser tree?  Maybe try to
> isolate the GRASS data so only it appears in the tree.
> > On Oct 11, 2016, at 10:15 AM, wkent <wkent at medinaco.org> wrote:
> > Sure, no problem.  See attached text file.
> > On 2016-10-11 11:07 am, William Kyngesburye wrote:
> >> Could you post a new crash log?
> >>> On Oct 11, 2016, at 9:42 AM, wkent <wkent at medinaco.org> wrote:
> >>> Great! 2.16.3 resolves the problem of not being able to access the
> GRASS tools from the Processing toolbox.  Thanks so much for the quick fix.
> >>> I am however still getting a crash when trying to work with existing
> GRASS data layers.  As soon as I click on a GRASS layer in the Browser
> panel, QGIS crashes.
> >>> On 2016-10-11 10:06 am, William Kyngesburye wrote:
> >>>> Install 2.16.3, this should fix GRASS problems.
> >>>>> On Oct 11, 2016, at 8:07 AM, wkent <wkent at medinaco.org> wrote:
> >>>>> I can run GRASS commands through the GRASS toolbox (using the GRASS
> plugin); but I am unable to run them through the Processing Toolbox.  I get
> the "This algorithm cannot be run :-(" error, and the QGIS log shows:
> >>>>> 2016-10-11T09:02:12       0       GRASS GIS 7 execution console
> output
> >>>>>                   /bin/sh: grass70: command not found
> >>>>> I have set the paths in both the Processing Toolbox options, and the
> GRASS Plugin options, to /Applications/QGIS.app/Contents/MacOS/grass7.
> >>>>> In regards to the crash I get when trying to add an existing GRASS
> layer (vector or raster) from the Browser panel to the Layers panel, the
> attached text file is the crash report that was generated.
> >>>>> Thanks so much for your help!
> >>>>> On 2016-10-07 5:51 pm, William Kyngesburye wrote:
> >>>>>> Loading GRASS data and using the GRASS toolbox are separate from
> using
> >>>>>> GRASS "algorithms" in the Processing plugin.
> >>>>>> The Processing plugin needs to know where GRASS is (set in
> Processing
> >>>>>> options, but defaults to bundled GRASS 7), and runs GRASS commands
> in
> >>>>>> a separate process than QGIS (should not crash QGIS).
> >>>>>> Loading GRASS data in QGIS needs no configuration of a GRASS path
> >>>>>> (this could crash QGIS if there is a bug or build problem).  Running
> >>>>>> GRASS modules does need configuration, but this also defaults to the
> >>>>>> bundled GRASS 7.  There is also a "general" GRASS option for the
> GRASS
> >>>>>> installation path, but this seems to default to the compiled GRASS
> >>>>>> location.  You can try setting this to the QGIS app:
> >>>>>> If you still get a crash, a copy of the crash log would help figure
> >>>>>> out what's wrong.
> >>>>>>> On Oct 7, 2016, at 1:30 PM, wkent <wkent at medinaco.org> wrote:
> >>>>>>> On 2016-09-29 8:45 am, Howard Frederick wrote:
> >>>>>>>> Recently upgraded to 2.16 - but cannot enable GRASS in the
> Processing configuration. Any ideas how to make this work?
> >>>>>>>> The folder seems to be correctly indicated in the config:
> >>>>>>>> This (and alternatives like ending as grass7/ ) give "This
> algorithm cannot be run :-(".
> >>>>>>>> Version: QGIS 2.16.2, on OS X 10.10.5.
> >>>>>>> Same error here, except running OS X 10.11.6.  It seems to be a
> path issue, although I have not been able to determine where the path is
> set.
> >>>>>>> Additionally, while QGIS is able to locate and open my existing
> GRASS locations/mapsets, when I click on a GRASS layer in the browser panel
> to add to the layers panel, QGIS crashes.
> >>>>>>> _______________________________________________
> >>>>>>> Qgis-user mailing list
> >>>>>>> Qgis-user at lists.osgeo.org
> >>>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> >>>>>> http://www.kyngchaos.com/
> >>>>>> "Those people who most want to rule people are, ipso-facto, those
> >>>>>> least suited to do it."
> >>>>>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> >>>>> <qgis_2-16-2_crash_report_loading_grass_layer.txt>
> >>>> "We can die but once, and that once we must die.  To be always
> >>>> fearing, then, would not avert it, and would make life miserable."
> >>>> - Tarzan, on death
> >> "Time is an illusion - lunchtime doubly so."
> >> - Ford Prefect
> > <qgis_2-16-3_crash_report_loading_grass_layer.txt>
> "Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting,
> and all for things that the beasts of the jungle would not deign to possess
> - money to purchase the effeminate pleasures of weaklings.  And yet withal
> bound down by silly customs that make them slaves to their unhappy lot
> while firm in the belief that they be the lords of creation enjoying the
> only real pleasures of existence....
> - the wisdom of Tarzan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161011/1327be86/attachment.html>
