[Qgis-user] Difference and Selection errors
Pim Verver pim at travelingo.nl
Wed Oct 26 02:46:08 PDT 2016
Dear all,
Working with the wonderful Processing  Modeler of QGis 2.18, I found two strange errors.
1)      On an normal intersect request, the SAGA Difference tool worked perfectly, while the QGis Difference resulted in an error: "Error executing algorithm Difference global name 'QgsWKBTypes' is not defined"
2)      Also I found that a QGis Select by location with the Within condition checked, results in 0 selections, whereas the v.select (Selects features from vector map (A) by features from other vector map (B)) with a Within setting, produces the - tested - correct selection of 1.
Does anybody else has the same experience with those tools?
Kind regards,
Pim Verver
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161026/bbe49fcb/attachment.html>
