[Qgis-user] Qgis2web help needed
Joris Hintjens jorishin at gmail.com
Mon Oct 31 13:02:48 PDT 2016
Woow Tony,
great work, thanks a lot!
No concatenated labels, I can live with that. Equal Interval graduated styling is too muc of a compromise for me. You see that the result is far less interesting. Logaritmic styling is essential here.
I’ll have a look at it next.
thanks again
Joris
> Op 31 okt. 2016, om 16:36 heeft Tony Pham <tony at fcm.com> het volgende geschreven:
> Hello Joris,
> Using your QGIS specific project file, I did receive error messages when trying to generate a qgis2web-based Leaflet or OpenLayers 3 web page of your map. I believe there are a few settings in your existing project file that produce issues when the QGIS2Web app runs its python script and hence you receive an error output. One example is the label field in which you employ a concatenation of two separate fields. I don’t believe QGIS2Web can handle the concatenation of multiple fields for its label.
> However, I was able to work around the error and generate a Leaflet-based page by performing the following:
> 1.       Removing the WorldRefug layer with the concatenated label along with all other layers from QGIS
> 2.       Re-importing the WorldRefug shapefile layer into QGIS
> 3.       Generating a “Graduated” style (Thematic map) based on UNHRDATNUM with “Equal Interval” mode
> 4.       Set up the WorldRefug layer such that there is No Label (the Qgis2web app has trouble with concatenating multiple fields for the label setting)
> Below is a screenshot of my qgis2web pop up app on a Mac platform with a preview of the working web page (I have also attached a PNG image for good measure):
> <image001.png>
> Hope this helps!
> Regards,
> -Tony
> On 10/18/2016 10:14 AM, qgis-user-request at lists.osgeo.org <mailto:qgis-user-request at lists.osgeo.org> wrote:
> Hi,
> All info about my issue:
> I made a nice map, which’d like to publish online.
> my map gives no result when trying to export with QGIS2Web.
> I’m just a poor lonesome mapper, and know nothing about coding, I cannot even define what the issue is.
> more info at
> https://dl.dropboxusercontent.com/u/23700421/refugeemapData.zip <https://dl.dropboxusercontent.com/u/23700421/refugeemapData.zip>
> with this link you can find:
>    - A consolidated project including all data (made in QGIS 2.14 on MacOS10.11)
> -some screen grabs from the Qgis2web UI with results and/or error messages
> as you can see, result is far from the original.
> Thanks for having a look at it.
> joris
> <Screen Shot 2016-10-31 at 11.32.32 AM.png>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161031/16959ae6/attachment.html>
