[Qgis-user] "live" openstreetmap data in qgis
kimaidou kimaidou at gmail.com
Thu Sep 1 01:08:21 PDT 2016
If your data is not that big, you could use QuickOsm processing scripts to
automate this a bit ( and use a macro at project opening to launch the
processing model you have build combining QuickOsm algs and others more
generic algs to do the job.)
If QuickOsm lacks some features, you should improve this plugin instead of
creating a new one, IMHO.
Regards
Michaƫl
2016-09-01 0:10 GMT+02:00 Robin Paulson <robin at bumblepuppy.org>:
> On 2016-08-29 02:56, Greg Troxel wrote:
>> Robin Paulson <robin at bumblepuppy.org> writes:
>> at the moment there are various ways to add openstreetmap data to
>>> qgis. as far as i can tell, they all rely upon downloading a
>>> .osm/obf/pbf file in some semi-automated way and importing it. none of
>>> the existing tools allow for any existing data to be deleted and
>>> replaced with the new.
>>> what i would like to do is add a "live" layer to my qgis projects,
>>> such that any data is periodically and transparently re-downloaded and
>>> updated. for those of you who are familiar with JOSM, this would be
>>> similar to the "continuos download" [sic] plugin for that software.
>> Two thoughts (and note that I don't use qgis yet, but do map for OSM):
>>   OSM resources can be somewhat easily overwhelmed, so some care in
>>   understanding the load put on servers is in order, unless you are
>>   talking about downloading from someplace outside of OSM that you're
>>   paying for access, etc.
> the data we are getting is currently around 1MB of .osm files. we may get
> more in future, but nowhere near enough to cause any problems.
>   People sometimes import OSM into postgis, and then apply
>>   daily/hourly/minutely diff files to keep their database up to date.
>>   Doing this and having qgis operate from the live database seems like a
>>   plausible way to do what you want.  A local database could also
>>   support other uses such as tile generation.
> yep, the workflow at the moment is to periodically use osm2pgsql to import
> new overpass-sourced data into postgis, but it's fiddly and requires me to
> maintain sql (i hate sql...) statements to process the data correctly, set
> up primary keys, maintain .style files, etc.
> i was hoping for something in existence already. maybe i build a thing
> myself out of my kludgy scripts and publish it.
> robin
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160901/8247f047/attachment.html>
