[Qgis-user] clip still not working on osm shape
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Thu Sep 1 07:30:49 PDT 2016
You are correct.  Sorry, I was working from memory.  Try Qgis geoalgorithms, Reprojection layer. You can search the processing plugin with"reprojection".
The right click is to activate toolbars for the "digitizing"and "advanced digitizing toolbars."
Nicolas
Envoyé de mon iPad
> Le 1 sept. 2016 à 09:57, Reginald Carlier <Reginald.Carlier at ingelmunster.be> a écrit :
> Hi Nicolas,
> I’m a little lost here. I use QGIS 2.16.1. When I right click next to the toolbars I see no plugin that changes the CRS.
> When I save a file there is no option to choose the input CRS and output CRS. You can choose the CRS and there’s a checkbox to choose the extent which is not checked by default. So I don’t know what to do if I want to change the extent to the new CRS.
> Which of the 111 geo algorithms should I use to change the CRS and reproject the extent?
> Regards,
> Reginald Carlier
> Deskundige GIS
> Gemeente Ingelmunster, Oostrozebekestraat 4, 8770 Ingelmunster
> T +32 51 33 74 39 www.ingelmunster.be
> Van: Nicolas Cadieux [mailto:nicolas.cadieux at archeotec.ca]
> Verzonden: donderdag 1 september 2016 15:24
> Aan: Reginald Carlier
> CC: qgis-user at lists.osgeo.org
> Onderwerp: Re: clip still not working on osm shape
> Hi,
> To modify the shape files, you need to activate the toolbars by right clicking next to a toolbar.  You will find a number of plugins also to help modify object.
> When you save a file, I think you have a input CRS and a output CRS.  Make sure the add both.  If it's not there, look in the processing toolbar for Qgis reprojection tools.  What version of Qgis are you working with?
> Nicolas
> Envoyé de mon iPad
> Le 1 sept. 2016 à 09:11, Reginald Carlier <Reginald.Carlier at ingelmunster.be> a écrit :
> Hi,
> No as I used QGIS Browser there is no option to save the changes. Also it would be great if there was an option to copy, paste or delete a shape.
> I guess I have to load the shape in QGIS and change the CRS and then use ‘save as’, but when I do that the saved shp shows in the same place as the unchanged shp.
> How can I adjust the extent so that it shows in the right location?
> Regards,
> Reginald Carlier
> Deskundige GIS
> Verzonden: donderdag 1 september 2016 14:50
> Hi,
> Did you resave the file in a new projection or just specified the layer projection by clicking on the layer in the layer manager?
> You need to save the file for the changes to be permanent.  There are also more complex reprojection tools in Qgis.
> Nicolas
> Envoyé de mon iPad
> Le 1 sept. 2016 à 08:35, Reginald Carlier <Reginald.Carlier at ingelmunster.be> a écrit :
> Hi,
> I found that the problem was the conversion of the CRS. When I select the shape of the town (Lambert 72) in QGIS Browser and choose WGS 84 as CRS the extent is still in Lambert coordinates. I tried the same in ArcMap and there I got the same result. Then I tried a function in the toolbox under Data Management > Projections and Transformations > Project where you can choose the CRS and also the transformation algorithm. Then the shape of the town was shown in the right spot. I wonder if there is such a tool in QGIS.
> Regards,
> Reginald Carlier
> Deskundige GIS
> Verzonden: donderdag 1 september 2016 13:36
> Hi,
> Are you running the latest Qgis 2.16? If so, vector tool should be in the processing toolbox and not in the vector menu.  I have only worked one day with 2.16 but it was long enough to see that it needed a complete removal of all previous versions as the menu had a mixe of the old and the new version.  After that, vector tools disappeared from the vector menu and reappeared in the new processing menu.  I had read about this in a French blog so I was expecting it.  Could this be the cause of your problem?
> If not, make sure both layers are in the same CRS (like you did) but that they also align properly when the "CRS on the fly" is not activated.  Try loading only those two layers.  You could test to see if it's the osm file format that is giving you problems by testing the two .shp file.
> Nicolas
> Envoyé de mon iPad
> Le 1 sept. 2016 à 05:33, Reginald Carlier <Reginald.Carlier at ingelmunster.be> a écrit :
> Hi Nicolas,
> I changed the CRS of the shapefiles so they match (EPSG 4326).
> It takes about 30 seconds before the algorithm (Vector > Geoprocessing > Clippen) finisches.
> Then it loads the resulting shapefile in QGIS but the attributetable is empty and the resulting shp is 1 kB.
> It looks as the Clip function doesn’t work.
> Regards,
> Reginald Carlier
> Deskundige GIS
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160901/89545c5c/attachment.html>
