[Qgis-user] Profile section digitising
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Sep 12 12:44:09 PDT 2016
There is a stratigraphy section in this plugin. It's made for archaeology.  I have been meaning to try this for a while now.  Have you both looked at it?
Nicolas
https://plugins.qgis.org/plugins/pyarchinit/
Envoyé de mon iPad
> Le 12 sept. 2016 à 15:25, John Harrop-3 [via OSGeo.org] <ml-node+s1560n5285387h58 at n6.nabble.com> a écrit :
> Lester,
> I’ve worked on that a number of times and on different GIS packages.  Usually the simple solution is to generate a profile using an arbitrate projection system - essentially creating another map, and then adding a frame with that map into the main layout/map your are building in composer.  You might need to use some pseudo coordinates like the projection your plan is in to make is simpler.  This can be helpful when your sections are N-S or E-W and then the elevation is an offset from the northing (or easting)
> Having said that, we are looking at the possibility of supporting an extension to QGIS that would develop into an open source section and drill hole package.  Adding that to QGIS will make it very attractive to many kinds of geological work.  We estimate that the cost of supporting the initial work will be not much different than a few commercial licences for … something else.
> Please let me know if this makes enough sense or you need other suggestions.  Or if you are interested in geological plugging for QGIS as well!
> Regards,
> John Harrop
> VP Exploration
> International Lithium Corp
>> On Sep 12, 2016, at 10:49 AM, Lester Anderson <[hidden email]> wrote:
>> Hello all,
>> I was wondering if anyone had advice or ideas about digitising profile
>> data (say on a geological cross-section) that is referenced to a
>> polyline in the project,
>> Thanks
>> Lester
>> Qgis-user mailing list
>> [hidden email]
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Profile-section-digitising-tp5285341p5285387.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Profile-section-digitising-tp5285341p5285392.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160912/ef746394/attachment.html>
