[Qgis-user] Ubuntu updating instructions
Jürgen E. Fischer jef at norbit.de
Tue Sep 13 07:23:53 PDT 2016
Hi Randal,
On Tue, 13. Sep 2016 at 00:21:21 -0400, Randal Hale wrote:
> It's a little bit confusing. There are like three repositories:
> stable, unstable, and testing. Testing you don't want (unless you
> want to test packages). Typically stable is a bit older. Unstable is
> current. Which doesn't really make sense - but that's the way it is.
Not like it matters much in this case.
We have packages in qgis.org/debian/ against the plain versions of the
distributions (debian and **ubuntu**) and in qgis/ubuntugis/ packages against
newer dependencies from - and only from - ubuntugis-unstable.
Looks like it's hard for people to accept that there are also ubuntu packages
in a directory called debian and that probably makes them jump on the other
because it has ubuntu in it's name.
> Under my /etc/apt/sources.list.d directory I made a qgis.list file
> and put the following in there:
> deb http://qgis.org/debian xenial main
> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu xenial main
Why?  That are the packages not based on ubuntugis with the dependencies from
ubuntugis.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160913/09cd8081/attachment.sig>
