[Qgis-user] Map composer. Wrong map scale
Carlo Cormio carlo.cormio at gmail.com
Wed Sep 14 01:20:27 PDT 2016
No, I'm using QuickMapServices plugin
Il 14/09/2016 09:39, Nyall Dawson ha scritto:
> On 14 September 2016 at 17:32, Carlo Cormio <carlo.cormio at gmail.com> wrote:
>> Dear all,
>> I'm using QGIS 2.12.3 on Windows 10. After printing a map using QGIS map
>> composer, I checked some distances and found that map scale was different
>> from the expected one.
>> I set ISO A3, portrait, as page size. QGIS project has EPSG:3857 (due to the
>> use of a google satellite layer), but most of the other layers have
>> EPSG:32633. I tell you this in case it could affect prints.
>> Map scale in print composer was set to 1:5000, but when I measured distances
>> (I also put a scale in the composition) I found it was more or less 1:3500.
>> The strange thing is that the ratio between the two scales is 1,41, that is
>> exactly ISO A3:A4 ratio.
>> What did I do wrong? Is there a setting I missed?
> Are you using the OpenLayers plugin?
> Nyall
>> Hope I gave all the necessary information.
>> Regards,
>> Carlo
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
