[Qgis-user] Organizing considering Dates
Tyler Veinot tylerkveinot at gmail.com
Wed Sep 14 08:21:08 PDT 2016
Thank you, Tyler.
my table was built with the sampling dates wells, however, every time the
sampling was done ... was created a line with the same coordinate to update
the sampling.
I believe so is being very difficult to establish a filter.
Bia;
Not sure though how that would effect filtering, one of those things where
I would need to see the data and try some expressions.
I would almost break the table up into 2 tables; Sampling Dates and Well
Points. Then use a relationship between the 2 tables (well_id pk in wells
and a well_id fk in samples). That should make the data simpler, and
perhaps provide a better ability to organise and filter.
Tyler
On Wed, Sep 14, 2016 at 11:49 AM, Tyler Veinot <tylerkveinot at gmail.com>
wrote:
> Bia;
> Sorry for the duplication but I am trying to keep my responses on the
> list. Unfortunately I often hit reply and not rely all:
> Bia;
> In 2.16.2 you can right click the column header and choose sort, this will
> bring up an expression builder. In there just add the field you want to
> sort by "Field_Name" or you can get fancy and say you want to sort by a
> number and a string field. Then you would do something like
> this "String_Field"||right(  ('00000000' || "Numeric_Field"), 8) Notice the
> "00000000" being added, that is because the expression treats the number
> like a string. Padding it with zeros sorts allows it to sort in order
> 1,2,3,4 if you do not pad you will end up with. 1,10,11,12,etc...
> Dual sorting with date is a bit tricky but you can store the data as a
> YYYY,MM,DD type and it should sort for you. If your date is stored in
> another way, i.e. DD/MM/YYYY then you will have to format it to YYYY,MM,DD
> for proper sorting, i.e. Year("Date")||Month("Date")||Day("Date") should
> work to that effect.
> As for sorting one column Ascending and another Descending I am at a loss,
> have not been able to figure that one out but someone here might add to my
> answer if you need to do that.
> Additionally if your using an older version of QGIS that does not have the
> "sort" function you could write the expression to a virtual field and then
> sort it by clicking the column header of the new virtual field.
> Hope that helps.
> Tyler
> On Wed, Sep 14, 2016 at 11:26 AM, Bia <bia.fs2000 at gmail.com> wrote:
>> Thank you, Tyler.
>> the sampling.
>> 2016-09-14 10:55 GMT-03:00 Tyler Veinot <tylerkveinot at gmail.com>:
>>> Bia;
>>> will bring up an expression builder. In there just add the field you want
>>> to sort by "Field_Name" or you can get fancy and say you want to sort by a
>>> should work to that effect.
>>> loss, have not been able to figure that one out but someone here might add
>>> to my answer if you need to do that.
>>> the "sort" function you could write the expression to a virtual field and
>>> then sort it by clicking the column header of the new virtual field.
>>> Hope that helps.
>>> Tyler
>>> On Wed, Sep 14, 2016 at 7:38 AM, Bia <bia.fs2000 at gmail.com> wrote:
>>>> Hi, how can I to organize my table considering the date? I tried a
>>>> expression but did not work.
>>>> And after I wanna compare other columns to have a precision table.
>>>> Thank you!
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Bea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160914/6a2e6678/attachment.html>
