[Qgis-user] qGIS crashes when working on rasters
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri Sep 16 06:17:59 PDT 2016
If you are using the latest Qgis on Windows 32 bit, there was apparently a bad package a few days ago.  Please download again and reinstall Qgis. I believe the problem has been fixed.
Nicolas
Envoyé de mon iPad
> Le 16 sept. 2016 à 08:56, Tudorache, Marian [via OSGeo.org] <ml-node+s1560n5286344h25 at n6.nabble.com> a écrit :
> Hi everyone,
> I am not sure if this issue was solved but QGIS has a rendering setting which allows allow using multiple CPU cores.
> I experienced those inexplicable crashes with QGIS 2.10 (Pisa).
> After I activated the setting Render layers in parallel using many CPU cores and put max cores at 8, everything was fine.
> The setting can be found in Settings/Options / Rendering.
> So if you have multicore machine takes advantage of this.
> I hope this helps.
> Marian
> -----Original Message-----
> From: Qgis-user [mailto:[hidden email]] On Behalf Of pzab
> Sent: September-09-16 3:43 PM
> To: [hidden email]
> Subject: [Qgis-user] qGIS crashes when working on rasters
> <http://osgeo-org.1560.x6.nabble.com/file/n5285026/qgis_crash.jpg>
> Hello,
> I am new user here and I would like to ask You for a solution concerning my problem.
> So...
> I downloaded and installed qGIS 2.14.6 LTR. I tried to follow this tutorial http://www.qgistutorials.com/en/docs/working_with_terrain.html.
> I got the raster, added it to my new project and when I insert the coords for Mt. Everest and change a scale I got the message qgis-ltr-bin stopped working. And it automatically closed qgis windows. I restarted my computer and try it again...and I got the same message.
> What can be the issue of this problem?
> Thank You very much in advance for helping me out.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-working-on-rasters-tp5285026.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-working-on-rasters-tp5285026p5286344.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-working-on-rasters-tp5285026p5286347.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160916/637ac707/attachment.html>
