[Qgis-user] imagery wrong print composer
Simon Muirhead
simon at simsurf.com.au
Tue Sep 20 03:20:32 PDT 2016
Thanks Andreas. I was pointed in the right direction a bit earlier and
quickmapservices worked perfectly
On Tue., 20 Sep. 2016, 20:17 Neumann, Andreas, <a.neumann at carto.net> wrote:
> Hi Simon,
> I am assuming that you are using the OpenLayers plugin.
> Please note that this printing offset is a known issue. I recommend you
> use the "Quick Map Services" plugin instead.
> Andreas
> On 2016-09-20 11:38, Simon Muirhead wrote:
> Hi, I am using qgis 2.12.0 lyon on the mac, and when i print a map with
> google satellite imagery the imagery in the wrong location, but it looks
> perfect in the work window and the print composer window. Something basic
> I am doing wrong?
> Regards, Simon Muirhead
> Written from my Nexus 6P so don't expect Tolstoy.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160920/28a88068/attachment.html>
