[Qgis-user] QField
F T oukile at gmail.com
Fri Sep 23 02:47:27 PDT 2016
Hello
I'm also disapointed with gptk raster : too slow, not easy to prepare
For QField, we rather use .mbtiles format, created from QGis and the QTiles
extension.
All formats that QGis uses can be converted in .mbtiles, it's very very
easy to prepare.
QField uses .mbtiles raster very well, it's fast to display
Tested with a 4Go .mbtiles
Fabrice
2016-09-23 11:20 GMT+02:00 F T <oukile at gmail.com>:
> Hello
> QTiles extension.
> easy to prepare.
> Fabrice
> 2016-09-22 9:32 GMT+02:00 Reginald Carlier <Reginald.Carlier@
> ingelmunster.be>:
>> Thanks Andreas,
>> Creating a Geotiff with pyramids did the trick. The only disadvantage is
>> that it created a file of about 1.7 GB (the original was 90 MB).
>> Now I am ready to test the app J.
>> Regards,
>> *Van:* Neumann, Andreas [mailto:a.neumann at carto.net]
>> *Verzonden:* woensdag 21 september 2016 16:19
>> *Aan:* Reginald Carlier
>> *Onderwerp:* Re: [Qgis-user] QField
>> Hi Reginald,
>> Did you create pyramids in the gpkg rasters?
>> Generally, Geotiff should be well supported - definitely more tested than
>> gpkg rasters. I had a 1GB geotiff on qfield (on SD-Card) and it displays
>> fast. I haven't tested vrt files with geotiffs - if it works as well?
>> Andreas
>> On 2016-09-21 15:44, Reginald Carlier wrote:
>> Hi Erwan,
>> You can look in the list of last week where I posted a couple of
>> questions about qfield and was pointed to the right website for
>> documentation.
>> I succeeded to publish a map on my phone but the aereal photo which was
>> published as a gpkg file doesn’t render. When I use the raster.gpkg on my
>> desktop it renders but very slow.
>> The gpkg file was created from a 90 MB jp2 file.
>> Regards,
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160923/c72b893d/attachment.html>
