[Qgis-user] Using QGIS/Atlas system-vars?
Elstermann, Mike Mike.Elstermann at itc-halle.de
Thu Sep 29 02:42:43 PDT 2016
Oops, found solution :-)
Use: [% @atlas_featurenumber %]/[% @atlas_totalfeatures %], it works fine.
mikeE., The geoObserver
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Elstermann, Mike
Gesendet: Donnerstag, 29. September 2016 11:02
An: 'qgis-user at lists.osgeo.org'
Betreff: [Qgis-user] Using QGIS/Atlas system-vars?
I want to use in QGIS/Atlas system-vars. In my textbox I write this:
Halle (Saale), [% "name" %]  [% @layout_page %] ... [% @atlas_pagename %] ... [% @layout_numpages %] ... [% @layout_pageheight %] ... [% @layout_pagewidth %]
Results:
* [% "name" %] works OK, gives correct names
* [% @layout_pageheight %] works OK, gives correct pageheight
* [% @layout_pagewidth %] works OK, gives correct pagewidth
* [% @layout_page %] gives only "1"
* [% @atlas_pagename %] gives only ""
* [% @layout_numpages %] gives only "1"
Where is the/my fault?
THX and best regards, mikeE., The geoObserver
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160929/cb3ac211/attachment.html>
